Loader Autumn Maintenance
装载机秋季保养
送走炎炎夏日,迎来清凉秋天,
在秋季,装载机应该如何保养呢?
Bidding farewell to the scorching summer and welcoming the cool autumn,In the fall, how should a loader be maintained?
动力系统检查
Power System Inspection
1.检查发动机机油油位;
2.检查散热器液位;
3.对散热器表面的灰尘杂物用高压空气(≤700KPa或7kg/cm2)清理散热器管、片之间的杂物,防止散热系统效率降低或失效;
4、及时清除发动机缸头油污。
1.Check the engine oil level.
2.Inspect the radiator fluid level.
3.Use high-pressure air (≤700KPa or 7kg/cm2) to clean any dust or debris on the radiator's surface, between the radiator pipes and fins, to prevent a reduction in the efficiency or failure of the cooling system.
4.Promptly remove any oil residue from the engine cylinder head.
传动系统检查
Transmission System Inspection
1、检查变速箱油位,检查并清洁变速箱呼吸器;
2、检查驱动桥油液是否充足,油液不足时及时添加;
3、检查清洁驱动桥呼吸器,保证呼吸器通道的畅通;
4、检查轮胎气压;
5、检查轮辋及重要部位的螺栓并进行紧固。
1.Check the transmission fluid level and clean the transmission breather.
2.Inspect the drive axle oil level, and top up if it's low.
3.Examine and clean the drive axle breather to ensure proper airflow.
4.Check tire pressure.
5.Inspect and tighten bolts on the wheel rims and important components.
电器系统检查
Electrical System Inspection
1、检查蓄电池状态
(1)检查蓄电池状态指示器(电眼):
绿色:蓄电池电量充足,可以正常启动车辆;
黑色:蓄电池电量不足,蓄电池需补充电;
白色:蓄电池报废,需更换。
2、检查皮带松紧度
(1)检查风扇皮带;
(2)检查空调压缩机皮带。
3、检查插头部位确认各接插件有无松动,针脚有无腐蚀,若有异常应使用专用清洗剂处理。线路要经常检查发现老化、破损时,必须及时防护或更换,以防止电器线路短路,酿成火灾。
1.Check the battery status.
(1) Check the battery status indicator (eye):
Green: Battery charge is sufficient, and the vehicle can start normally.
Black: Battery charge is low, and the battery needs recharging.
White: Battery is faulty and needs replacement.
2.Check the tension of belts.
(1) Inspect the fan belt.
(2) Inspect the air conditioning compressor belt.
3.Examine plug connections to confirm whether connectors are loose, pins are corroded. If any abnormalities are found, use a specialized cleaning agent. Electrical wiring should be regularly inspected for signs of aging or damage, and must be adequately protected or replaced in a timely manner to prevent electrical shorts that could lead to fires.
制动系统检查
Brake System Inspection
1、检查行车制动性能、检查驻车制动性能;
2、检查制动加力泵油位,油液不足时及时添加;
3、清理加力泵盖表面的污泥垢,确保油杯盖排气孔及呼吸器通道的畅通;
4、检查制动钳刹车片磨损程度,磨损过多时及时进行更换;
5、对于配装空气干燥罐的机型,必须按照保养要求进行保养。
1.Check the driving brake performance and inspect the parking brake performance.
2.Check the brake booster pump fluid level, and top up if it's low.
3.Clean the surface of the brake booster pump cover to ensure the vent holes in the fluid cup cover and breather are clear.
4.Inspect the brake caliper and brake pad wear level, and replace them promptly if they are excessively worn.
5.For models equipped with an air dryer tank, maintenance must be carried out according to the maintenance requirements.
- END -
山东恒旺集团以“让最广泛的用户享受最高性价比的产品及服务”为使命,不断推出新产品,提供全方位服务。主营产品类目齐全,包括挖掘机、推土机、钻机、打桩机、压路机、履带运输车等20大系列180余种。产品通过ISO、欧盟CE、德国TUV、法国BV等十余项安全检测认证。
Shandong Hengwang Group, with the mission of "providing the widest range of users with the highest cost-effective products and services," continuously introduces new products and offers comprehensive services. Our main product categories are comprehensive, including excavators, bulldozers, drilling rigs, piling machines, road rollers, tracked transport vehicles, and more, totaling over 20 series and 180 varieties. Our products have obtained more than ten safety testing certifications, including ISO, EU CE, Germany TUV, France BV, and others.
干工程、选恒旺、事业兴旺!
免费热线:400-9975-666
欢迎您的致电~
For quality construction, choose Hengwang and prosper your career!
Toll-free hotline: 400-9975-666
