挖掘机积灰隐患大,清洗指南一键get!
2023年09月10日 11:51
恒旺集团
责编:戚金荣
作者:恒旺集团
挖掘机现已成了工程机械施工中必不可少的设备之一,它减轻了人类在许多领域所不能涉及的作业,在日常施工中,它一般以修路,挖破,挖下水道等多方面的工作。
挖掘机运行完毕后,必须对挖掘机履带,机壳,空气滤芯,铲斗等多方面进行清洗。这个清洗如何是保证以后在施工中能否顺利进行的一个重要环节,否则就会发生挖掘机出现故障的。
Excavators have now become indispensable equipment in construction machinery. They alleviate tasks beyond human capabilities in various fields. In daily construction, they are commonly used for tasks such as road repair, excavation, and creating drainage systems.
After an excavator's operation, it's crucial to perform a thorough cleaning of various components, including the tracks, body, air filters, and bucket. This cleaning process is essential to ensure smooth operations in future construction tasks. Neglecting this step could lead to malfunctions and issues with the excavator during operation.
Step One
Diesel Softens Grease
把柴油倒到喷壶里面,喷向黄油处,等10到30分钟后,再进行一次刮洗,这次可以用钢丝球用力刮去污垢,一般油漆不会刮掉。
Pour diesel fuel into a spray bottle and apply it to the greasy area. Wait for 10 to 30 minutes, then perform another round of scrubbing. For this step, you can use a wire brush to vigorously remove dirt. Usually, the paint won't be affected.
Step Two
Heavy Oil Cleaner Softens Again
将柴油用完后,倒进重油清洁剂,进行喷洒。这里几个地方要注意:重油清洁剂有强大的去油能力,使用前先喷洒一点到油漆上面进行所谓的皮试有的机子油漆太差或时间太差,喷完后导致油漆脱落和发白,重油清洁剂有较强腐蚀性,会腐蚀皮肤,和指甲,很疼很痒,注意要带上胶手套,有条件可以带上眼镜,或购买不伤手的重油清洁剂。
After using up the diesel fuel, pour in heavy oil cleaner and begin spraying. There are a few points to note here: heavy oil cleaner has strong degreasing capabilities. Before use, test a small amount on the paint to ensure compatibility. Some paints, due to poor quality or aging, might experience peeling and whitening after application. Heavy oil cleaner is corrosive and can cause skin and nail damage, leading to discomfort and itching. Make sure to wear rubber gloves and, if possible, protective eyewear. Consider purchasing a heavy oil cleaner that is gentle on hands if available.
Step Three
Softening for Cleaning Again
喷完柴油和重油清洁剂后,黄油开始发软了,再重复上面步骤,再把污垢再刮除一次,不排除有的刮不动,这时候就要使用洗手粉这东西,这东西专门去油污,再配合钢丝球加在一起就可以轻轻松松去掉那些刮不动的油污了。
After spraying diesel fuel and heavy oil cleaner, the grease starts to soften. Repeat the previous steps and scrape away the dirt once more. If some spots are still hard to remove, you can use hand cleaner powder. This product is designed to remove grease stains. Combine it with a wire brush to easily get rid of the stubborn grease that couldn't be removed before.
Step Four
Surface residual stains wiped off
油污清理得差不多了,这时候漆面有很多沾手的油水在上面,这时候再用洗衣粉兑水,然后用洗衣粉水再对漆面进行擦拭。
Once the grease has been cleaned up, you might notice that the painted surface has some oily residue on it. At this point, you can mix laundry detergent with water and use this mixture to wipe down the painted surface.
Step Five
Rinse with a High-Pressure Water Gun
用高压水枪进行冲洗,基本就干净了,没有高压水枪可以用清水慢慢洗,也可以洗得非常干净。如果还不干净,重复以上几个步骤就可以了
Rinse the surface using a high-pressure water gun to achieve a thorough clean. If a high-pressure water gun is not available, you can use regular water to clean gradually, and you can still achieve a satisfactory result. If the surface is not completely clean, you can repeat the above steps.
挖掘机的使用极大地提高了工业施工的效率,只要挖掘机保持干净,重要运作部位天天维护,就能增加挖掘机的寿命,通过以上介绍,相信大家对这个问题已经有所了解。
The use of excavators has significantly increased the efficiency of industrial construction. As long as the excavator is kept clean and its key operational components are maintained regularly, the lifespan of the excavator can be extended. With the information provided above, I believe everyone now has a better understanding of this topic.
- END -
山东恒旺集团以“让最广泛的用户享受最高性价比的产品及服务”为使命,不断推出新产品,提供全方位服务。主营产品类目齐全,包括挖掘机、推土机、钻机、打桩机、压路机、履带运输车等20大系列180余种。产品通过ISO、欧盟CE、德国TUV、法国BV等十余项安全检测认证。
Shandong Hengwang Group, with the mission of "providing the widest range of users with the highest cost-effective products and services," continuously introduces new products and offers comprehensive services. Our main product categories are comprehensive, including excavators, bulldozers, drilling rigs, piling machines, road rollers, tracked transport vehicles, and more, totaling over 20 series and 180 varieties. Our products have obtained more than ten safety testing certifications, including ISO, EU CE, Germany TUV, France BV, and others.
干工程、选恒旺、事业兴旺!
免费热线:400-9975-666
欢迎您的致电~
For quality construction, choose Hengwang and prosper your career!
Toll-free hotline: 400-9975-666
