铁甲工程机械网> 工程机械资讯> 行业 > GENMA成功中标海外客户两台多功能门座式起重机订单
近日,GENMA成功中标海外客户两台50吨四连杆多功能门座式起重机(简称:门座机)订单,标志着GENMA在市场开拓领域实现新突破,为品牌全球化战略布局再添新动能。
根据客户定制化需求,该批次GENMA门座机将配备集装箱吊具、抓斗以及吊钩三种工作装置,覆盖多元化作业场景。凭借其多功能设计,单台设备即可高效完成20英尺/40英尺标准集装箱、各类散装物料以及件杂货的装卸作业,有效提升客户所在港口的综合装卸能力与运营效率。
在电气系统方面,设备将集成全数字式交流变频调速、PLC智能控制及前端能量回馈系统等先进技术,提升设备在复杂工况下的作业稳定性与操作精度,同时通过能量回收机制有效降低设备运行能耗,助力客户构建绿色、可持续的港口运营模式。
该笔订单产品,将由GENMA的高端装备制造基地——南通润邦重机有限公司生产制造。润邦重机将充分依托其在高端装备领域的技术经验,秉持“完美履约”理念,以精益制造和严苛品控确保订单产品的高品质交付。
GENMA Secures Overseas Order for Two Multi-functional Portal Cranes
GENMA has recently won a bid to supply two 50-ton multi-functional double level luffing jib crane (also known as portal cranes) to an overseas client, marking a significant breakthrough in its market expansion efforts and adding new momentum to its global brand strategy.
Customized to meet the client's specific requirements, these GENMA portal cranes will be equipped with three types of working attachments: a spreader, a grab, and a hook, enabling them to handle diverse operational scenarios. Thanks to their multi-functional design, a single crane can efficiently load and unload 20-foot/40-foot standard containers, various bulk materials, and general cargo, significantly enhancing the comprehensive handling capacity and operational efficiency of the client's port.
In terms of the electrical system, the cranes will incorporate advanced technologies such as full digital AC variable frequency speed control, PLC intelligent control, and a front-end energy feedback system. These features improve operational stability and precision under complex working conditions, while the energy recovery mechanism effectively reduces energy consumption, supporting the client in building a green and sustainable port operation model.
The cranes will be manufactured by GENMA's high-end equipment production base—Nantong Rainbow Heavy Machineries Co., Ltd. (RHM). Leveraging its technical expertise in the high-end equipment sector and adhering to the "flawless execution" philosophy, RHM will ensure the on-time and high-quality delivery of the order through lean manufacturing and strict quality control.
【点分享】
