Just as lubrication is the wise choice for machines, cooperation is also the "lubricant" for economic development. Sinopec Grease will take you to explore the friction and lubrication mechanism of grease, support the SCO Summit with innovative lubrication technology, and contribute more Chinese strength to the smooth operation of the global economy.
On the precision stage of industry, the friction between metal components just like a fierce battlefield. How can grease, with its semi-solid wisdom, build a protective lubrication barrier during the running of mechanical equipment gear mesh and bearings rotate?
Hello everyone, I am Sinopec Grease, emerge in laboratories where engineers dedicate day and night to research.
I am the guardian of industrial machinery, a semi-solid lubricant precisely formulated from base oil, thickener, and additives. These three components, works as a well-coordinated team, at both micro and macro levels to weave a lubricating defense for mechanical parts.
When the pressure of machine startup arrives, I’ll activate my protection mode with the triple secret codes, showing my prowess in different scenarios.
From extreme cold to high temperature, from precision instruments to heavy load machinery, from the deep sea to outer space, I resolve friction between metals with my flexible semi-solid form. Choosing me means choosing to stand alongside quality and assurance.
