近日,由GENMA技术团队研发设计、南通润邦重机有限公司生产制造的GENMA门座式磁力吊顺利交付行业客户。
该设备在传统门座式起重机基础上进行了多项创新设计,兼具电磁吊与吊钩双功能,电磁吊模式下设备起重量达40吨,吊钩模式下可达55吨,可灵活应对钢板及件杂货的卸船作业需求。
其核心亮点包括:
具备360°全幅度回转能力,大幅提升设备操作灵活性与工作范围覆盖能力;
整机采用轻量化、低轮压结构设计,适配多数码头承载条件;
设备吊具支持伸缩调节及±120°回转功能,可高效卸载不同规格钢板,大幅提升设备装卸效率。
GENMA致力于通过不断创新的技术和服务,为行业客户提供高性能、定制化的物料搬运和装卸解决方案。此次交付的门座式电磁吊,以轻量化、多功能和强适应性为核心优势,将进一步助力客户优化物流效率,降低运营成本。
Recently, the GENMA portal slewing magnetic crane, R&D designed by the GENMA technical team and manufactured by Nantong Rainbow Heavy Machineries Co., Ltd. (RHM) was successfully delivered to industry client.
Based on traditional portal slewing cranes, this equipment has undergone multiple innovative designs, integrating dual functions of magnetic lifting and hook lifting. Its lifting capacity reaches 40 tons in magnetic lifting mode and 55 tons in hook mode, enabling flexible response to the ship unloading needs for steel plates and general cargo.
Its core highlights include:
Equipped with 360°full-range slewing capability, significantly enhancing operational flexibility and working range coverage;
The entire machine adopts a lightweight, low wheel pressure structural design, compatible with the bearing conditions of most terminals;
The equipment's spreader supports telescopic adjustment and ±120° slewing function, allowing efficient unloading of steel plates of various specifications and greatly improving loading and unloading efficiency.
GENMA is committed to providing industry customers with high-performance, customized material handling and loading/unloading solutions through continuous technological innovation and quality services. The delivered portal slewing magnetic crane, with its core advantages of light weight, multi-functionality and strong adaptability, will further help customers optimize logistics efficiency and reduce operating costs.
【点分享】
