铁甲工程机械网> 工程机械资讯> 行业 > 柳工LD36D推土机全新上市
柳工LD36D推土机全新上市
柳工LD36D推土机
全新上市
LiuGong LD36D Bulldozer is Newly Launched
柳工于2023年推出LD36D推土机,目前已成功导入印尼、阿联酋、巴布亚新几内亚、南非等多个国家,主要用于露天矿山、煤电厂、采石、水利水电等重载极限工况,并将于2024年6月起替换B320推土机全面上市。
LiuGong began introducing the LD36D bulldozer in 2023, and it has already been successfully deployed in several countries, including Indonesia, the UAE, Papua New Guinea, and South Africa. It is primarily used in heavy-duty extreme conditions such as open-pit mining, coal power plants, quarrying, and water conservancy projects. Starting in June 2024, it will fully replace the B320 bulldozer.
发动机功率大、动力强劲
High engine power and strong performance
净功率达
330hp
相比B320功率提升
9%
The net power reaches 330 hp
9% increase compared to the B320
扭矩储备高
High torque reserve
低速恒定
高扭矩
1627N.m
在转速范围内
高效提供
最佳性能
With a constant high torque of 1627 N.m at low speed
it efficiently provides optimal performance within the speed range.
生产率提高
Increased productivity
标准的半U铲
容量达
9.6m
单工作循环内
生产率提高
15%
The standard semi-U blade capacity reaches 9.6m³
improving single-work-cycle productivity by 15%
传动平稳
Smooth transmission
卓越的整机性能,先进的模块化传动技术,让传动更加平稳。
The excellent overall machine performance and advanced modular transmission technology ensure smoother transmission.
more
油耗降低
Reduced fuel consumption
E(经济)模式和P(重载)模式,匹配不同的工况需求,外加节能的液压散热系统,让整机的效率更高,整体油耗下降5-10%。
The E (economy) mode and P (heavy-duty) mode match different working conditions. Combined with the energy-saving hydraulic cooling system, the overall fuel consumption decreases by 5-10%.
more
安全无忧
Safe and worry-free
由重型钢材焊接而成重载底盘,保证设备在恶劣的工况下能够承受较大的冲击载荷及扭转力,保证客户使用无忧
The heavy-duty chassis, welded from heavy steel, ensures the equipment can withstand significant impact loads and torsional forces in harsh conditions, providing worry-free use for customers.
more
作业环境舒适
Comfortable working environment
升级的豪华驾驶室内,行走和工作液压均为液压先导控制,操作更加轻便精确,290°全景视野,84dB以下的操作环境让操作者能在舒适的环境下作业。
The upgraded luxury cabin features hydraulic pilot control for both travel and work hydraulics, making operation easier and more precise. The 290° panoramic view and an operating environment below 84 dB allow operators to work comfortably.
more
发动机一站式维护
One-stop engine maintenance
轻松、便利维护,减少了设备使用者的许多顾虑。
Easy and convenient maintenance reduces concerns.
有奖征集
欢迎与我们分享更多您与柳工的故事。
分享内容一经采用,
即有定制好礼赠送!
相关图片、视频及文章(未经发表)
可发送至:
overseas.marketing@liugong.com
2002年提出“建设开放的国际化柳工”至今,柳工已拥有超过30家海外子公司&机构,4座海外制造工厂,5大全球研发基地,300多家经销商,为170多个国家和地区提供产品和服务。在打造具备全球竞争力的世界一流企业背景下,柳工将持续积极建设全价值链协同发展的全球战略合作伙伴关系,坚定推进全面解决方案、全面智能化、全面国际化的“三全”战略。
In 2002, LiuGong put forward the globalization strategy. Since then, LiuGong has had over 30 overseas subsidiaries & offices, 4 overseas manufacturing plants and 5 R&D bases spreading across the world. More than 300 dealers provide LiuGong products and services to the customers in over 170 countries & regions. Guided by the reform of building a world-class enterprise with global competitiveness, LiuGong will continue to actively build a synergistic global strategic partnership across the entire value chain by firmly promoting the "Total Globalization, Total Solution and Total Intelligent" strategy.
关注我们
