铁甲工程机械网> 工程机械资讯> 行业 > 恒旺挖机“度夏”有绝招,赶紧收藏!
恒旺挖机“度夏”有绝招,赶紧收藏!
夏季来临,面对高温天气,不仅挖掘机面临考验,司机也需要特别注意。在作业过程中,挖掘机常因高温产生多种故障。如果驾驶员能注意以下几点,则能有效减少故障的发生,确保安全高效地完成工作。
With summer approaching and high temperatures on the rise, both excavators and their operators face significant challenges. During operations, excavators often encounter various malfunctions due to the heat. If operators pay attention to the following points, they can effectively reduce the occurrence of these malfunctions and ensure the safe and efficient completion of their work.
PART.ONE
发动机维护
Engine maintenance
HENGWANG
降温防气阻:夏季高温导致发动机因高转速和散热困难易出现气阻现象,需立即停车降温排除故障。
随时观察水温表防缺水:高温天气行车要时刻检查冷却水量和水温表,发现缺水应怠速降温后再加水,避免烫伤。
机油防变质:高温使润滑油变稀,抗氧化性变差,应使用夏季专用润滑油,定期检查和更换润滑油。
Cooling to Prevent Vapor Lock: High temperatures in summer can cause vapor lock in engines due to high RPMs and difficulty in cooling. Immediate stopping and cooling are necessary to troubleshoot this issue.
Monitor the Water Temperature Gauge to Prevent Water Shortages: During high-temperature weather, it's essential to continuously check the coolant level and the water temperature gauge. If a shortage is detected, allow the engine to idle and cool down before adding water to avoid burns.
Prevent Oil Degradation: High temperatures can thin lubricating oil and reduce its oxidation resistance. Use summer-specific lubricating oil and regularly check and replace it.
PART.TWO
冷却系统管理
Cooling System Management
HENGWANG
及时清洗发动机外表油污:厚重的油污会影响散热,增加故障风险,应使用高压喷射方法清洗发动机部件。
防止水箱水温过高:冷却水蒸发快,出车前加足冷却水,工作中经常检查水位,出现开锅现象时减速运转,待水温下降后再慢慢添加冷却水。
保证最佳供油时间:调节好挖掘机的供油时间,避免供油过早导致敲缸或反转,供油过晚导致发动机无力。
Timely Cleaning of Engine Surface Oil: Thick oil deposits can affect heat dissipation and increase the risk of malfunctions. Use high-pressure spray methods to clean engine components.
Prevent High Water Temperature in the Radiator: Coolant evaporates quickly in high temperatures, so fill the coolant before heading out and frequently check the water level during operation. If boiling occurs, reduce the engine speed and wait for the water temperature to drop before slowly adding more coolant.
Ensure Optimal Fuel Supply Timing: Adjust the fuel supply timing of the excavator properly. Avoid early fuel supply, which can cause knocking or reverse rotation, and late fuel supply, which can result in a lack of engine power.
PART.THREE
电池与润滑管理
Battery and Lubrication Management
HENGWANG
选用黏度大的润滑油:高黏度润滑油可提高性能和密封性,更换时要彻底清洗机油滤清器、集滤器和油底壳,调整柴油机转换开关至“夏”位。
正确使用蓄电池:夏季应适量减少电解液并加蒸馏水,控制比重在1.25左右,定期检查和添加蒸馏水,长时间不工作时应拆下蓄电池,放在通风干燥处,定期充电并保持外部清洁。
Choose High Viscosity Lubricating Oil: High viscosity lubricating oil can improve performance and sealing. When changing the oil, thoroughly clean the oil filter, oil strainer, and oil pan, and adjust the diesel engine switch to the "summer" position.
Proper Use of the Battery: In summer, reduce the electrolyte and add distilled water, maintaining a specific gravity of about 1.25. Regularly check and add distilled water as needed. If the equipment is not in use for a long time, remove the battery, store it in a well-ventilated and dry place, charge it periodically, and keep the exterior clean.
HENGWANG
夏季保养
高温天气不仅对挖掘机是考验,对驾驶员也是挑战,需做好以上措施,确保安全高效度过夏季。
High temperatures are not only a test for the excavator but also a challenge for the operator. It is essential to implement the above measures to ensure a safe and efficient summer.
-END-
山东恒旺集团以“让最广泛的用户享受最高性价比的产品及服务”为使命,不断推出新产品,提供全方位服务。主营产品类目齐全,包括挖掘机、推土机、钻机、打桩机、压路机、履带运输车等20大系列180余种。产品通过ISO、欧盟CE、德国TUV、法国BV等十余项安全检测认证。
Shandong Hengwang Group, with the mission of "providing the widest range of users with the highest cost-effective products and services," continuously introduces new products and offers comprehensive services. Our main product categories are comprehensive, including excavators, bulldozers, drilling rigs, piling machines, road rollers, tracked transport vehicles, and more, totaling over 20 series and 180 varieties. Our products have obtained more than ten safety testing certifications, including ISO, EU CE, Germany TUV, France BV, and others.
干工程、选恒旺、事业兴旺!
免费热线:400-9975-666
欢迎致电
